Hi Joe...thank you for that...I kind of assumed that was the case. As I understand it the skin comes with the styles and pane layouts but as far as content is concerned you add that yourself...so what you see when you buy the skin is something you would need to copy (modules..etc) in order for it to look like that?? the skin I'm working on is
www.copiaportals.net ....which is based upon the snowcovered "8 websites" skin...this one... http://site434.mysite4now.net/eingtech7/dnndemo/Home/tabid/3927/Default.aspx
I'm very new to this so undertanding the filing structure and what I need to edit in order to see changes is a bit of learning curve. Understanding the relationship and differences between a "Portal" and "Site" is something I need to understand more...especially when uploading a skin. So far as I understand it...you upload a skin via either the "Portal" or "Admin" if via Portal the skin is copied to all portals?? and if you upload a skin via"Admin" it's accessible to only that portal??
One more question...if I create a page (other than the homepage) can i base all other new pages on that second page (and not the homepage)?
Thanks for your help Joe and sorry for this "War and Peace" email.
Doug
It's not that i think things are missing...it's just getting my head around the filing structure once a skin is uploaded (installed) I guess...so I can use css to style images and text positioning. (I'm pretty good with css...at least :o)
