Lee Sykes DNN Creative Staff
 Nuke Master VI Posts:4945
Martin Desaulniers
 Nuke Newbie Posts:2
03/02/2010 4:51 PM |
I just registed to your manazine. I don't found any link to watch the video tutorial ? I keep circuling around the same page. Can you help ? |
jesp18
 Nuke Active Member Posts:23
03/03/2010 6:31 AM |
Hi Lee,
I've installed the Feedback Module on my local installation (DNN 5.1.4). I've added some categories and subjects and changed the settings. No problems so far. When I fill in the form and send it I get an error (see attachements).
Can you help me with this?
Thanks and kind regards, Jeannine |
03/03/2010 6:51 AM |
Check your installation's Event Log and post the more detailed error message that you'll find there.
Also, is SMTP setup? Have you successfully sent emails from the system?
jesp18
03/03/2010 7:07 AM |
Hi, I've checked my smtp settings and also did a test. Email was send succesfully.
Event log. ModuleId:
436 ModuleDefId: 110 FriendlyName:
Contactformulier ModuleControlSource:
DesktopModules/Feedback/Feedback.ascx AssemblyVersion:
5.1.4 PortalID: 0 PortalName: K2 Infra -
Consultants UserID: 1 UserName:
hostus01 ActiveTabID: 63 ActiveTabName:
Organisatie RawURL: /k2infra/Organisatie.aspx AbsoluteURL:
/K2Infra/Default.aspx AbsoluteURLReferrer:
http://localhost/k2infra/Organisatie.aspx UserAgent: Mozilla/4.0
(compatible; MSIE 7.0; Windows NT 6.0; GTB6.4; SLCC1; .NET CLR 2.0.50727; Media
Center PC 5.0; .NET CLR 3.5.21022; .NET CLR 3.5.30729; OfficeLiveConnector.1.3;
OfficeLivePatch.0.0; .NET CLR 3.0.30729) DefaultDataProvider:
DotNetNuke.Data.SqlDataProvider,
DotNetNuke.SqlDataProvider ExceptionGUID:
70d7d233-e879-4d4b-8c06-5ed1f2fb816c InnerException: Value cannot be
null. Parameter name: pattern FileName: FileLineNumber:
0 FileColumnNumber: 0 Method:
System.Text.RegularExpressions.Regex..ctor StackTrace:
Message: DotNetNuke.Services.Exceptions.ModuleLoadException: Value
cannot be null. Parameter name: pattern ---> System.ArgumentNullException:
Value cannot be null. Parameter name: pattern at
System.Text.RegularExpressions.Regex..ctor(String pattern, RegexOptions options,
Boolean useCache) at System.Text.RegularExpressions.Regex.Match(String input,
String pattern) at DotNetNuke.Modules.Feedback.Feedback.IsEmail(String Email,
Int32 portalid) at DotNetNuke.Modules.Feedback.Feedback.cmdSend_Click(Object
sender, EventArgs e) --- End of inner exception stack trace
--- Source: Server Name: PC_VAN_JEANNINE
Kind regards, Jeannine
03/03/2010 7:15 AM |
Hmmm.
You might want to try adjusting the modules settings to see if you can determine which parameter is causing the problem. For example, turn off moderation and turn off categories. If you have checked "Use category value as Send To" turn that off and make sure that there is a valid email address in the Send To setting.
The problem appears to be related to an email address, so pay attention to the module settings related to email addresses.
jesp18
03/03/2010 7:33 AM |
It's going wrong when I enable the setting: Use
Category value as Send To. There is a valid email address in the value field (see attachment). It looks like the system is not picking up this value.
When I disable this setting email is sent.
03/03/2010 7:45 AM |
I've never used this option before. I believe that Lee does discuss category values in the current tutorial (I haven't actually had a chance to view it yet), so you might want to review that if you haven't already done so.
But, at least we've located the source of the problem.
jesp18
03/03/2010 8:19 AM |
Hi Joe,
Lee does discuss the category values and yes, I've viewed them. I followed the tutorial, but I still got the error. It seems like the module is not picking up the list value for the category. Maybe Lee can have a look at it again. Maybe it's an DNN 5.1.4 issue?
jesp18
03/04/2010 3:00 AM |
Hi Lee,
Thanks for this answer. I never did an upgrade till now. So another challenge for me.
jesp18
03/04/2010 6:53 AM |
Hi Lee and Joe,
Thanks for the great and fast support!
David
 Nuke Master Posts:152
03/04/2010 12:54 PM |
For a simple module this one has caused me no end of grief over the years.
I use Google apps for my email provider. They have very strange settings and also you can’t send yourself emails. As a result I use WebMaster@AgingSafely.com as the admin address and DavidWSnow@AgingSafely.com for to receive email. Google also uses SLL and strange ports. I have yet to have DNN allow me to specify a port (465) on the line with smtp.gmail.com. However, DNN or Google seem to do the right things and the mail comes thru.
However, if the users is not logged in and fills out the message using their email address I don’t receive the email address in the email. This makes the module somewhat useless.
For example I as a test I get “Test message Submitted By: Dave Snow”
I am using the current feedback module but and older version of DNN.
/Dave Snow
David
03/04/2010 3:14 PM |
After hours of screwing around I proved that Google won't let you send emails using anyones elses name. That was causing it to look like WebMaster@AgingSafely was sending the Feedback not the purson filling out the form.
Verizon isn't so security minded and if I use them as the SMTP server then the feedback "looks" as if it was sent by the email address entered on the form.
/Dave |
Martin Desaulniers
 Nuke Newbie Posts:2
03/04/2010 3:59 PM |
What is your email ? I have your receipt and the PayPal receipt also. I want to get to this tutorial : http://www.dnncreative.com/Tutorial...fault.aspxand right now, there is only a description of the video (even when I'm login ... my name appear on the top right of the web site beside logout. |
sglindo
 Nuke Newbie Posts:2
03/28/2010 8:29 AM |
So where exactly is the feedback module. I can't seem to find it listed anywhere in my installation (Ver 5.02.03). Or does it need to be downloaded. |
03/28/2010 2:37 PM |
Logged in as host, visit the Host, Extensions page and click the "Install Available Updates" link at the bottome of the page. The Feedback module should be listed there. If not, you will have to download and install it separately.
