Lee Sykes DNN Creative Staff
 Nuke Master VI Posts:4945
Mad Marcus
 Nuker Posts:15
09/28/2010 12:46 AM |
I have just upgraded our DNN instal to 5.5.1 and figured it was time I looked into the Taxonomy side of things so following your video tutorial I have registered the tag in the skin .ascx file for our site and everything is fine. However as soon as I put the skin object on the page i.e. -dnn:TAGS runat="server" id="dnnTags"- the whole site throws to the DNN error page with the link to return to the site and the following in the address bar. http://...........Default.aspx?tabi...&content=0 Any ideas on what is causing this or how to prevent it would be appreciated. |
09/28/2010 7:35 AM |
Could you post the entire error trace from the Event Log?
Mad Marcus
 Nuker Posts:15
09/28/2010 5:48 PM |
Thanks Joe,
This looks to be the relevent bit.
AssemblyVersion: 5.5.1
UserAgent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.2; .NET4.0C)
ExceptionGUID: 8d27e247-529d-47e5-a5a4-086f36c40997
InnerException: Sequence contains more than one element
FileName:
FileLineNumber: 0
FileColumnNumber: 0
Method: System.Linq.Enumerable.SingleOrDefault
StackTrace:
Message:
DotNetNuke.Services.Exceptions.PageLoadException: Sequence contains more than one element ---> System.InvalidOperationException: Sequence contains more than one element at System.Linq.Enumerable.SingleOrDefault[TSource](IEnumerable`1 source) at lambda_method(ExecutionScope ) at System.Linq.EnumerableExecutor`1.Execute() at System.Linq.EnumerableQuery`1.System.Linq.IQueryProvider.Execute[S](Expression expression) at System.Linq.Queryable.SingleOrDefault[TSource](IQueryable`1 source) at DotNetNuke.Web.UI.WebControls.Tags.get_TagVocabulary() at DotNetNuke.Web.UI.WebControls.Tags._Lambda$__4(Term cat) at System.Linq.Enumerable.WhereSelectListIterator`2.MoveNext() at System.Linq.Enumerable.Count[TSource](IEnumerable`1 source) at DotNetNuke.Web.UI.WebControls.Tags.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at ASP.portals_0_skins_amazon_maroon_boxed_medium_width_ascx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at ASP.default_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Page.Render(HtmlTextWriter writer) at DotNetNuke.Framework.PageBase.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) --- End of inner exception stack trace ---
Mad Marcus
 Nuker Posts:15
09/29/2010 5:39 PM |
Yes, there are a number of Tags defined and 5 of these have been assigned to pages in the page settings but obviously you can't see them without being able to add the token to the page. |
09/29/2010 6:35 PM |
Hmmm ... I'll keep looking. In the meantime, you might want to take this over to the DotNetNuke forums, too. |
Mad Marcus
 Nuker Posts:15
10/01/2010 2:39 AM |
Thanks Joe, I have posted that and will let you know if I get it resolved. |
Mad Marcus
 Nuker Posts:15
10/07/2010 2:03 AM |
I managed to get this sorted out. DNN had somehow added an additional application scope System Vocabulary so there were 2 rows in the database for user tags. Once I manually removed the duplicate row everything was OK (It couldn't be done without editing the database directly). |
Michael Poltenovage
 Nuke Newbie Posts:1
12/12/2010 6:21 PM |
I followed your videos, but when I go to a page setting or a module setting and select the tags menu, only the first line is displayed. Nothing I created display in the pull down menu. I am running DNN 5.6. Any ideas? |
WinXnet
 Nuke Master Posts:156
04/08/2011 10:33 AM |
Is there a way to quickly display all tags/tag hierarchy of the site? Also, the tags do not appear to be searchable via the built in DNN Search. Is this true? |
http://www.winxnet.com
Emerson Bruce - http://chayadigital.wordpress.com |
ollivogt
 Nuke Active Member Posts:24
05/18/2011 10:12 AM |
Hello, I have some issues with displaying tag clouds - may be you guys can give me some hint on it.... I did create some tags in admin > Taxonomy First: none of the tags is displayed in module settings. This is not an issues for me at the moment as I do not intend to use this functionality but may be part of the bigger problem.... Module from Sea Star Software: Displays tags and link to search page results (I have only the trial version) => this works fine! WatchersNET.TagCloud: displays tags but does not display any results on the search results page => this works half way... DNN Rad Tag Cloud: does not display any tag (and hence no link to search results) => this does not work at all.... I am running 05.06.02 (144) (this is an upgrade from an earlier version) Is there any setting in the web config etc. that I need to know? Many thanks. Oliver
05/18/2011 1:14 PM |
You might want to check with the developers of those modules to see if they are supposed to work with the tags implemented by DotNetNuke. |
ollivogt
05/20/2011 12:32 PM |
Hi Craig, Watchers.net and DNN Rad Tag Cloud are both from codeplex. They do support the standard DNN Taxonmoy... and as I've said they do work to a certain extend... - the trial tag cloud version from Sea Star Software works fine! - DNN Rad Tag cloud does not work at all - watchers.net shows the tags but the search results page is empty... - watchers.net however works fine if I choose the "common words" option - the search page shows me e.g. on which page I've used the word "business" but this is not what I would like to see... Many thanks for your help. Oliver
