Lee Sykes DNN Creative Staff
 Nuke Master VI Posts:4945
Hunter McDonnell
 Nuke Newbie Posts:9
06/02/2010 11:15 AM |
I've logged in, but I cannot download the tutorial? |
Hunter McDonnell
 Nuke Newbie Posts:9
06/07/2010 9:33 AM |
HELLO? I log in and it still says "Subscribe" to download this tutorial? John |
Hunter McDonnell
 Nuke Newbie Posts:9
07/06/2010 9:21 AM |
My company has subscribed to this a while ago... I wonder if they chose not to renew the subscription...? Thanks. John |
Tim Rhodes
 Nuke Newbie Posts:1
07/20/2010 4:27 AM |
Just subscribed and this was the first series I watched. If the rest of the tutorials are as clear and detailed as this one, it will be well worth the subscription. Very nicely done.
You mention the ability to create our own skin for the gallery module. Can you point me in the right direction for creating and installing one?
Thanks |
07/24/2010 8:50 AM |
The Gallery module uses "Themes" which you will find in the Themes folder: DesktopModules/Gallery/Themes.
If you look in that directory, you will find several folders, each contains a separate theme. If you look further, you'll see that the theme is really a CSS file.
Study an existing theme to see how it works.
To create a new theme, I would recommend that you copy an existing one, directory and all. Then rename the files, edit the CSS, and add your own images as you need them.
Palatine Web
 Nuke Active Member Posts:33
09/03/2010 6:18 PM |
Using DNN 5.5 and .net 4 this module is not in the core available modules. I downloaded it from DNN Site but it is a .net 2 module and hence does not work on my DNN do you know of a work around or a patch to fix this issue as I have built my entire site around DNN 5.5 and do not want to have to reinstall an older version just to get one module working. |
Paul Turner Palatine Web Support http://www.palatineweb.com |
09/03/2010 6:54 PM |
I believe that the Media Module is the current version of what once was Gallery.
09/04/2010 7:43 AM |
Whoops! Further digging, however, shows that the Gallery module is not dead. The home page for the project is here. The Gallery Forum is here. The latest version of the Gallery module is not included with Version 5.5.0 of DotNetNuke. Here is a comment posted to the Gallery Module forum (dated 8/27/10).
"Gallery 04.03.01 RC fixed several issues related to running
under ASP.Net 4.0 for DNN versions 5.04.xx. However, due to a behavior
change in the core FolderController.AddFolder method introduced in DNN
5.05.00, Gallery will throw the error you are experiencing. I hope to
have a Gallery 04.03.02 Beta or RC up on CodePlex by late next week.
Although I have fixed this issue, I also want to take this opportunity
to fix other few minor issues. Assuming all goes well with community
testing of the Beta or RC, I will then submit the new package to the
release tracker testing process to become an official release."
Justin
 Nuker Posts:13
02/01/2011 11:09 AM |
Hello, I am trying to find a module that will show normal sized pictures that fade in and out. I want users to visit my home page and automatically the slide show begins and the users do not need to click on anything. The core gallery module shows the pictures as thumbnails and not normal sized pictures and a user must click on the module to start a slide show. If this module does not perform what I need it to do, what module can I use for this task? Again, the home page loads and the user sees a slide show of normal sized pictures and not thumbnails and the user does not need to click anything to start the slide show, it just automatically starts on page load. thanks for any help! /Justin |
02/01/2011 6:12 PM |
I have had a lot of success using Ultra Video Gallery.
If you want to try the "free" route, both Will Strohl and Oliver Hine have nice gallery modules. Google the names and you'll find them.
gopinath ramalingam
 Nuke Newbie Posts:3
04/03/2012 7:03 AM |
how to use the jquery in dnn6 module....my jquery is not workinig |
