Lee Sykes DNN Creative Staff
Nuke Master VI Posts:4945
David
Nuke Newbie Posts:7
05/06/2010 11:23 AM |
Lee, Great tutorials on Super stylesheets! I just have one problem...even after I apply all of the code that you showed in the SEO .css file, I still have about a 2 or 3px whitespace gap with the scroll bar still showing. Do you have any suggestions on how I can fix this?
Also, I meant to add, the gap is not just on the SEO skin, but on all of the skins....(3Col,2Col,1Col,MultiLayout,Portal,and Blog) Thanks, David |
PSpeth
Nuke Active Member Posts:33
05/07/2010 6:18 AM |
I thought this was a very interesting article. There were two things I wasn't crazy about. - Using the dropdown Listbox for the admin menu
- Moving the admin bar to the bottom of the page.
I will try to play with the design and see if there is a way to avoid these choices. Thanks again for an article with incites into the latest techniques. |
Fred
Nuke Newbie Posts:8
05/07/2010 12:33 PM |
Great tutorial! I do have a question though. Is it possible with the DNN version of the YUI library to have two columns each 50%. I know that it is possible with the YUI version. I may be missing the obvious. Thanks. <!--EndFragment--> |
Fred Larson www.projcomplete.com |
Fred
Nuke Newbie Posts:8
05/14/2010 9:56 AM |
Okay... Thanks for the response and thanks for this great resource. |
bobmc
Nuke Active Member Posts:24
05/24/2010 8:31 PM |
Lee...When I add the code for the search bar to be at the top right, its added as expected, however the search area is double the size now. To fix this I simply changed UseDropDownList="true" to "false", which removed that little icon. Even though I problably won't use the drop down option, at this time, I'd like to have the option for the future. Did I miss a step somewhere?
also if I set both ShowWeb="false" ShowSite="false" will it default to the site or just simply not work?
Thanks and great work..
Bo |
bobmc
05/24/2010 8:49 PM |
I haven't gone through all the video yet, but was wondering is the option of setting up the default menu vs the list menu in one of the CSS Skinning tutorials, if so which one.
I tried to compare one of the Vortex container.ascx files and I can see some differences but honestly I'm still a bit confused.
Bob |
bobmc
05/25/2010 10:33 PM |
Thanks for the info Lee, however I may not have asked my Menu question correctly. I was trying to refer to PSpeth's question about not using the dropdown Listbox for the admin menu. I'd perfer to use the default menu vs. the Listbox menu on the containers. I can't seem to find what all tokens and/or code i need to change or add to make it use the default admin menu.
I did some research and I think I may need to use the [ACTIONS] and/or [ACTIONBUTTON]tokens but not sure of the formatting, I even looked through the MinimalExtropy containers and didn't really get it.
Bob |
05/26/2010 12:53 AM |
For the containers you will want to use the [ACTIONS] token for the menu.
[ACTIONBUTTON] is for elements such as the print icon, RSS icon, edit module link etc.
If you are styling with an ascx skin you need to add these lines of code: (spaces added so the code displays in the forum)
(at the top) < % @ Register TagPrefix="dnn" TagName="ACTIONS" Src="~/Admin/Containers/SolPartActions.ascx" % >
(in the body of the container) < dnn:ACTIONS runat="server" id="dnnACTIONS" ProviderName="DNNMenuNavigationProvider" ExpandDepth="1" PopulateNodesFromClient="True" / >
Styling with object code in a html file (DNN 5): (spaces added)
< object id="dnnACTIONS" codetype="dotnetnuke/server" codebase="ACTIONS" > < param name="ProviderName" value="DNNMenuNavigationProvider" / > < param name="ExpandDepth" value="1" / > < param name="PopulateNodesFromClient" value="True" / > < / object >
Styling using tokens: (spaces added) (you can view this code in DNN4.9.x Minimal Extropy Containers - it works in DNN5) In the html file [ACTIONS]
In the container.XML file < Object > < Token >[ACTIONS]< / Token > < Settings > < Setting > < Name >ProviderName< / Name > < Value >DNNMenuNavigationProvider< / Value> < / Setting > < Setting > < Name >ExpandDepth< / Name > < Value >1< / Value > < / Setting > < Setting > < Name >PopulateNodesFromClient< / Name > < Value >True< / Value > < / Setting > < / Settings > < / Object >
aventure
Nuke Newbie Posts:3
05/26/2010 8:18 AM |
Hi, Do you know of a way to force the footer to the bottom of the screen when using the super style sheets? |
05/26/2010 8:39 AM |
Do you want to force the footer to be at the bottom of the screen? You could use absolute positioning. The SuperStyleSheets tutorials show how to put something at the top of the screen with absolute positioning in CSS. You could do the same at the bottom, though I can think of a number of ways that this might be messy or unappealing. It all depends on the user's screen size and the size of the content within the page.
bobmc
05/26/2010 12:48 PM |
Thanks Lee! I think I see what I was missing now..
Bob |
aventure
Nuke Newbie Posts:3
05/27/2010 2:43 AM |
he original author of the style sheets uses a method dicussed here, http://matthewjamestaylor.com/blog/...f-the-page but when I apply this in the super stylesheets, the pages that are larger than a page have a foter half way up rather than pushed to the bottom. Has anyone managed to get a footer to force to the bottom of the dsiplayable page, ie if te page is short it wans to be pushed to the bottom of the displayble area if not then as normal at the bottom of the content. |
Tom
08/06/2010 2:34 PM |
I know I'm a little late to this thread but I just finished watching and working on these tutorials. I too had a question about using the dropdown lists for the container menus. It seemed like you switched to this method to avoid incomplete drawing of the menu when the container height was small. I'm seeing the same problem in my custom skin but not in the Minimal Extropy skin as a reference. I'm using the same container (I think) so I don't understand why my container menus are getting cut off. Hope that makes sense. Thanks, Tom |
Smitty07
Nuke Newbie Posts:1
08/09/2010 1:59 PM |
Lee, I loved the Super Stylesheet Video and worked along with them. The last video (12) I was unable to get my ASCX file to read a different (new) stylesheet. I created the new stylesheet, gave it the same name as the skin, added the tags and saved. It is still reading the "Skins" stylesheet, with the Logo, Menu and Breadcrumb sitting under the footer.
Instead of creating a new folder to avoid changing tags that are being used in a different skin, I would love to have the option to add a new stylesheet.
Thanks so much for any help getting it to See the new stylesheet! Debbie |
Joel
Nuker Posts:18
08/29/2011 12:14 PM |
This video is GREAT! I wonder , how can i set the width of thee skin? i want 980px witdh in all skin, and be centered. Can you help me? Thanks you
