You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
DNN Creative Articles
Working with File Action in OWS - Issue 53
Last Post 02/20/2014 11:09 PM by
. 7 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
01/29/2010 6:22 AM
Add any comments or questions regarding the
tutorial from
Issue 53
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Andre Decio
12/11/2011 4:26 AM
Hi there. I've posted a similar question in the Mushroom RAD forum. Just need to know how to develop a News list including images/vids using OWS. Cheers for any advice.
DNN MVP
12/12/2011 5:44 AM
RAD or OWS?
Joe Craig,
Patapsco Research Group
Complete DNN Support
Andre Decio
12/13/2011 1:29 AM
From the tutorials I've seen on OWS and Mushroom RAD, the RAD seems more usable. Cheers.
Question on a slightly different matter: I want to make a pdf file downloadable from my website. Using a a href=..... but cant seem to get the URL right. Is there something else I need to configure to enable this file to be dowloadable? If I have the pdf in my root folder for the portal what's the correct URL reference (or is that something I have to get my web hosts to define in IIS or whatever ?)
Cheers
DNN MVP
12/13/2011 6:40 AM
My characterization would be that OWS has a steeper learning curve than RAD. You can do both simple and complex modules using both products.
As for the file question, you can simply link to the file using the Editor in most modules. You will get a link that uses the LinkClick function. If the file is in the Standard file system, you can refer to it by name so your link should be something like
http://mysite.com/Portals/N/myfilename.pdf.
(Assuming you are using Portal N)
Joe Craig,
Andre Decio
12/16/2011 9:10 PM
Thanks Joe, I was forgetting to add the '/portals/n/' extension!
I'm definitely getting slower (brain!) and still can't get my head around how to create vb.net code and respond to events. Probably because I've only used Visual Studio 2008 up to this point. Are there any example sites I can look at the source code and work it out? I suppose my main (stupid) confusion is the fact that .aspx files are what I've worked on so far. The events can be 'trapped' from the code behind. But for a .ascx file can I do the same thing? If for example I put some vb.net code in a .ascx file to respond to eg. a PageLoad event, and I put some more code in another .ascx file (on the same page), which one runs first? Or am I talking out of my earhole as usual. Cheers
Cam
02/20/2014 5:00 PM
Is it possible to restrict the file type uploaded in the File Action in OWS?
I want my users to be able to upload PDF files only?
Is this possible?
Please help
DNN MVP
02/20/2014 11:09 PM
I don't know. I haven't been keeping up with OWS, but I know that there is a group that uses it.
You'll probably get the best advice if you as on the OWS forums at
http://www.openwebstudio.com/Commun...orums.aspx
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
