Hi All,
Firstly, thanks so much for all your useful tips and tutorials Lee. The subscription to DnnCreative is money well spent!
I've been using HouseMenu on all our DNN projects for quite some time now, and i love it.
I have a client who has asked if they can have their dropdown menu
aligned horizontally, not vertically.. this is a top horizontal menu,
not a vertical side menu. the best way to explain is by example. This
is what they want it to be like:
http://www.tjkdesign.com/articles/n...own/LO.asp
and
http://www.microsoft.com/windows/products/windowsvista/
now looking at the html of both of these, it's just nested ul and li's, so that's a good start.
I'm asking the question of whether this is possible because i've never seen an example of this orientation of a DNN housemenu.
Has anyone done this successfully?
Are the any problems with this approach and DNN/housemenu?
I just don't want to waste time trying if there is a reason why this might not work with the housemenu.
It should work in IE6, IE7 (maybe i should also be testing in IE8 now!?), Firefox 2 (3?), and Safari 3
Many thanks for your time!
Tim
