Wow, those sites both look really professional. I really like the composite mouldings. Nice boat!!!
Some comments:
For composite, there is a lot of text on this site. Bear in mind the average web viewer is lazy and won't be bothered to read more than a few lines of text, unless its something they are specifically interested in. Keeping text succinct yet allowing people to view more is difficult but it works. Perhaps using an announcements style module would allow some (but not all) text descriptions to be truncated with a "more ..." link if people want to see more.
Other than that its great. really looks good.
For Fasset:
1. The flash on the homepage is good, but I would suggest making a different movie for all other pages, otherwise every time you switch pages, the "Fasset" logo jumps in from the left. So for instance, if you had an animated slide in movie for homepage, then another movie where the logo text was static but the red dots moved on all other pages. Otherwise its distracting (I think)
2. For the maps, I suggest maybe using google maps plugin. This one works great.
http://www.ploufs.net/aspnet/Google...fault.aspx Those sites are really professional looking. Well done!
