You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
DNN Creative Articles
Issue 22 - Backup a live Install SQL 2000 --> localhost SQL Express 2005
Last Post 04/30/2008 3:46 AM by
. 12 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
guimu
04/02/2008 1:50 AM
I have downloaded issue 22 about live & localhost synchronisation.
I have not seen it yet because i wanted to know first if i could use these instructions to backup my live install on a SQL 2000 Server and tranfert it on a localhost installation using SQL 2005 Express.
Would it be possible to do?
Guillaume Mullier
Founding Partner at Live Data Security
DNN MVP
04/02/2008 8:21 AM
Yes, you can.
Joe Craig,
Patapsco Research Group
Complete DNN Support
guimu
04/02/2008 1:15 PM
OK thanks
Guillaume Mullier
04/07/2008 3:51 AM
you can go from SQL 2000 to 2005 - but I'm unsure if you will then be able to transfer a localhost 2005 database to to a live SQL 2000 database, I don't think this will be possible.
If you wish to transfer between local and live, you can get hold of a developers only license of SQL Server 2000 for a very low cost through places such as amazon.
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
guimu
04/17/2008 2:10 PM
Thank you Lee, I want to migrate to SQL Server 2005.
I have a new question about this tutorial: almost everything worked fine, but i have a problem with links and images. No image is showing and all the links are broken. Do you have any idea of how i could repair that.
What will be the behaviour once i transfer to live instalation again?
Thank you.
Guillaume
Guillaume Mullier
04/17/2008 3:31 PM
We cover the problems with images and links here:
Find and Replace SQL queries for DotNetNuke
(To fix problems after transferring a localhost database to a live website and other useful functions)
DotNetNuke Podcasts
Twitter:
DNN MVP
04/17/2008 7:22 PM
And, to do that search and replace I recommend the F3 module that is free from Engage Software. It simplifies the process greatly and you can do the search and replace without doing any SQL stuff.
Joe Craig,
guimu
04/19/2008 10:15 AM
Thank you both for your answers.
I used Engage F3 Module which is really a great tool and I have solved the whole problem in 10 minutes!
Guillaume Mullier
guimu
04/28/2008 4:54 AM
I was able to replicate my live website on my localhost installation.
Then i wanted to replicate it to a new server, but i went into the following issue: I can't login any more.
When in clic the login button, it gives a http 404 error.
I tried to install a new DNN Site from the install files, and had the same issue. I guess this is a problem of IIS cnfiguration.
Any Sugestion?
Guillaume Mullier
04/28/2008 6:30 AM
have you had a look at the tutorials on how to install a fresh installation of DotNetNuke:
How to install DotNetNuke to Vista
How to install DotNetNuke 4.5 to Windows XP Pro with IIS
they may point you in the right direction. - things to check:
you are using asp.net 2.0 framework
correct security permissions have been set up on the DotNetNuke installation files
web.config file has correct settings
if this is a new server, for troubleshooting I would first try to get a fresh installation of DotNetNuke working. once you have that working, it will then be easier to transfer a localhost installation to the new server.
DotNetNuke Podcasts
Twitter:
guimu
04/28/2008 3:59 PM
That's exactly what i did when i saw that things were going wrong, I installed a fresh version and had the same problem: I can't go to the loggin page, neither the Register one.
The only active page is the Home page.
It is a new server W2003 R2 Standard Edition
I had some configuration problems, so I suppose that the best way to solve this issue follow will be to start again removing any install app and setting up again.
Thank you for your help.
Guillaume Mullier
guimu
04/29/2008 7:09 AM
I just reinstall IIS and then regiisasp.exe and that was it.
Guillaume Mullier
04/30/2008 3:46 AM
great, glad to hear you got it sorted,
DotNetNuke Podcasts
Twitter:
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
