Hi all, here's another of my random problems I can't seem to solve! ...
I am developing a dotnetnuke site using the snapsis navmenu to provide a simple horizontal menu. I would like to use sIFR to replace the font on the menu items. Below is a screenshot of how my menu currently looks:
If I do a straight replace on the links on the menu using sIFR, this is what I get:
Yikes!!!
I was wondering if anyone has successfully used sIFR with navmenu to replace the font, and if so, how did they do it? Does it require modifying the markup outputted by the NavMenu component (is this even possible?). To be honest, if this is really hard I won't bother, as the menu looks good as it is. It would be nice to be able to do this though
Any help would be greatly appreciated,
Thanks!!
For reference, the markup used to embed the snapsis navmenu and the css used to style it are included below:
Snapsis:NavMenu class="adminHostList" ID="AdminHostList" Level="0-1" Type="SelectList"IncludeTabs="Admin,Host" runat="server" />
/* CSS styles for Main menu container */
#snapsis_nav ul
padding:0;
margin:0;
list-style:none;
float:left;
background-color:Transparent;
/* Main menu items */
#snapsis_nav li
position: relative;
float:left;
line-height:39px;
width:8em;
list-style: none;
font-size:1em;
border-right:1px solid #444;
/* First level links */
#snapsis_nav a
font-size:1em;
font-weight:bold;
display:block;
text-decoration:none;
text-align:center;
width:auto;
height:39px;
padding:0;
color:#DDD;
/* First level menu links-hover */
#snapsis_nav li a:hover
background:transparent url(images/nav_bar_mo.gif) repeat-x;
/* Second level menu container */
#snapsis_nav li ul
line-height:1.25em;
position: absolute;
left: -999em;
height:auto;
margin:18 0 0 0;
background:transparent;
border:1px solid #000;
/* Second level menu items */
#snapsis_nav li li
margin:0;
width:13em;
line-height:2.0em;
height:auto;
background:transparent url(images/sub_nav.png) repeat;
/* Second level menu links */
#snapsis_nav li li a
width:13em;
margin:0;
padding:2px 0 2px 0;
height:auto;
border-bottom:1px solid #404040;
border-right:0px;
