I found the How to create DotNetNuke Portals (Parent and Child) tutorials to be most helpful. (Sorry I did not have them when we were first setting up our portals.)
However, what about augmenting the with a discussion of SSL? I have been struggling with SSL implementation and some things that would be helpful include the following:
Use Cases
- ✓ Single site with separate DNN installation
- Parent with multiple child portals sharing the parent SSL
- Multiple sites (separate IIS, separate IP addresses, separate SSL
certifications) with one DNN installation. (when SSL works on one site
it does not work on another site)
- Multiple sites (one IIS, one IP address, multiple names in host header value, one SSL certificate)
# ! is quite simple but the others seem to take some fancy footwork between IIS and DNN that we have not yet grasped.
Additionally, if you could show the use of the admin settings "SSL URL", and "Standard URL" using a separate certificate that would be ideal. Everyone says what they are for but there are no examples of the IIS/DNN settings that would be needed for these to be used.
Again, Thanks for the work. This is the second year we have subscribed and you tutorials are a life saver.
Matthew [script removed]Submit
