I used the code changes for the .MainMenu_MenuContainer and it worked as shown. I reloaded the base skin file from the Install package - and I still have the change!
Here is the code change that worked:
This styles the main menu container for the root menu items. The default.css file uses a
border
background-color
I then FTPd the original skin file back in - and No Change! I still had the yellow bar with green border. I stopped the web.config file and rrestarted it, with no change.
Any suggestions on howto get rid ofthe yellow bar and green border?
