Some suggestions for further skinning updates.1> adding a skin object that would automatically select font size, and page widths. (similar to that seen on the DNN site.2> I looked at a skin that had a very robust layout. Something like this: [ Top Pane ] [ LeftPane ][ RightPane ] [ LeftPane2 ][ Contentpane ][ RightPane2 ] [ Bottom Pane ] [ LeftPane3 ][ Contentpane2 ][ RightPane3 ] [ Bottom Pane2 ] Of course this was created with tables, and empty panes wouldn't show. It would give quite a bit of flexibility to the page creators without requiring multiple skins. - Is something like this a do-able extension of your latest skin using divs? - What are your opinions on this approach?
