You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Skinning Toolkit
Skinning Toolkit
Question about the favicon
Last Post 01/29/2010 8:43 AM by
Paul Taylor
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
brenda
02/14/2008 11:46 AM
What do I need to do in order to change the favicon? Do I have to change anything in my default.aspx or web.config or can I just delete the favicon.ico in the root folder and change it with a new favicon?
Thank you so much for the help.
DNN MVP
02/14/2008 6:13 PM
You should actually put the favicon in the root directory for the site. What you put in Portals/_default will be the default favicon for any site that doesn't have one. Put the favicon for site 0 in Portals/0, etc.
And, while you are at it, you can get rid of the favicon file in the root web directory.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Roshdy
02/26/2008 7:25 AM
the portal must refresh when browse with firefox
how to solve this problem
i use ajax in all behavior in the site
DNN MVP
02/26/2008 6:55 PM
The favicon is stored in the user browser's cache. Clearing the cache on the browser will fix it.
Joe Craig,
Rob Roberts
02/24/2009 5:31 PM
No matter how I refresh, I don't get the favicon in my site with IE7 (works fine with FireFox).
http://www.stearmangroup.com.
Favicon should look like a small biplane like the logo on the template site.
IE7 has flushed all cache and restarted the browser and DNN, but nothing seems to work.
I'm about 2 build several sites on this same installation and want different faves for each. Suggestions?
Paul Taylor
01/29/2010 7:20 AM
I am having same problem. No matter what file I put in the portal root e.g. Portals\0 an old favicon is displayed. I have deleted all icons including defaults but this does not make any difference. The current icon is one that I placed there several months ago and it now refuses to go away. I have restarted the application and also updated the web.config file to try and flush the cache but no joy.
I have tested on client machines that have never visited the site and they also display the old favicon.ico and not the new version. Ahhhhhhhh!!!!
Paul Taylor
01/29/2010 8:43 AM
Found a work around. I found a tip on another forum
http://www.dnnskin.com/KnowledgeBas...vicon.aspx
that allows you to point to a different location for the favicon.ico file. I tried this and it worked first time. Simply place the following line in the HEAD section of default.aspx and specify the new location. link rel="SHORTCUT ICON" href="/Portals/0/favicon.ico" The strange thing is that I now have the favicon back in the portal root (see above) and the new favicon displays every time. However, if I remove the line above from default.aspx the old favicon (that no longer exists) returns.
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Skinning Toolkit
Skinning Toolkit
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
