DotNetNuke 3.2.1 and 4.0.1 have just been released.
These are both stabilisation releases with a number of key bug fixes.
The 3.2.1 release contains an updated version of the Microsoft
MemberRole component which addresses some Medium Trust issues on
ASP.NET 2.0.
A variety of defect corrections and new versions of the FreeTextBox rich text editor control are also included.
The DotNetNuke Installation Guide.pdf in the documentation download has
also nearly doubled in size to 63 pages. This addresses some of the areas
of documentation weakness raised in various threads in the asp.net forums.
Upon quickly reading the new documentation, it is a vast improvement
and should clarify a lot of the questions that have been raised in the
forums.
In particular they address the following issues which have been raised:
If you are using version 3.2.1 with ASP.NET 2.0 and your website
hosting provider is running under Medium Trust, you need to make some
additional adjustments to your web.config file, you can read about
these on page 18 of the new documentation.
If you are using version 4.0.1 and your website hosting provider is
running under Medium Trust you can find details regarding this on page
35 of the new documentation. - The documentation states to use the
development.config file instead of the release.config file if you are
running under Medium Trust. (The development.config file is not
included in the install.zip download file, it's included in the
source.zip/website folder download file.)
I haven't tested installing DNN4.0.1 in a Medium Trust environment yet, so I can not confirm the process.
I will be testing DNN 4.0.1 over the next month or so and will provide
further information when I have fully tested the setup on a live
website.
You can download the latest releases from:
http://www.dotnetnuke.com/Default.aspx?tabid=125
