Hey Lee - Maybe you could do a video tutorial on how to accomplish this???
I'm was using DNN 4.6.2 with the FCK Editor that comes with it. Now I've upgraded it to DNN 4.8.0 with the standard FCK Editor. I'm having the same problem with either version.
I want to have a different toolbar set for different user groups. I've created a different toolbar set, added it to the web.config file, and it shows up under the HOST log-in. However, the "disable" check box is greyed out for all of the different toolbar sets.
When I select the customized toolbar set for the specific group, there is no way to "save" my selections, either for the instance, module, or portal. It goes back to giving everyone access to the DNN-Default Toolbar, but only if the module is "displayed" on the page. If the module is not displayed, the "basic" toolbar is available and I cannot change the options for adding/removing the different buttons.
Why can I not select a given toolbar set with a user group and "save" it so when a member of that particular user group logs in, the custom toolbar set I've created shows up and works for that user?
Right now, the forced options are either the complete toolbar set (if the module is displayed on the page) or the "basic" toolbar set (if the module is not displayed on the page). I need some options in-between those extremes and to eliminate the forced option of "make all toolbars available for all users" into an option that I can choose if necessary.
Has anybody had any luck at all with doing this? I can't believe I'm the only person trying to do this.
I also tried this on DNN 4.5.5 and it does the same thing. The options to do this seem to be there but they don't work. Does anybody know why?
This is SO frustrating. Thanks in advance for your help.
