Hello! This is a great site – I’ve learned much about skinning from here.
I thought it would be a fun little side project to make some commercial DNN skins. I have just completed my first attempt, and as this is the first complete skin package I have made, I’ve decided to give it away for free. To download it, just go to:
www.webwhirlers.com/business-sleek/ If you do decide to check it out, I would love to hear any comments you might have on it, good or bad.
Does anyone know of a resource on the web that lists the ‘best practices’ when it comes to creating DNN skins? There are a lot of things I am unsure of. Solpartmenu – It’s a powerful system, but a real mess to work with. I’ve noticed that most commercial skins out there uses this though.You think people would be less likely to purchase a skin If it doesn’t use the solpart menu?
Login, register, etc. – Most skins I have seen puts the login and register links prominently at the top of the design, and that’s what I did for this skin. Personally, for my corporate sites I would prefer a discrete login at the bottom, and no register at all. Any opinions?
Search – I’ve build 500+ websites, and only on a few occasions has the customer requested a search function on their site. Most professional DNN skins seems to have have the search included though. Is this a feature that you feel should be included in all skins?
Pane Structure – I have seen commercial skins with up to 20 panes in one page. This seems to me that it would just make the skin less user friendly. I tried to keep my structure simple, and create a few different templates, rather than one huge one to fit all needs. Is this a bad idea?
Color Variations and Containers – There are skins with dozens of colors and hundreds of containers. Seems to me that this would just be more confusing than anything else. Would you rather spend $30 for a smaller skin that has the color you want. Or $90 for a skin that comes with all this extra stuff?
