"From 12th February Microsoft will start an automatic transition from
IE6 to IE7. Administrator’s from different companies which still uses
Windows Server 2003 or XP, now gets a possibility to avoid this
automatic installation of IE7. Microsoft has just released a tool which
can be used to deactivate the automatic installation of IE7. The tool
will however only work if you are using Windows XP SP2 or Windows
Server SP1 2003. You can download them from Microsoft
here."
For those of us who make CSS (no tables) skins, this is welcome news. Surely within weeks of these automatic updates the percentage of IE6 users will drop from about 26% to under 10% and we can stop spending as much time making a skin work well in IE6 as we do on all the rest of the skin design and implementation.
However, if you are still going to test using IE6, I recommend that you make sure that your system doesn't get automaticly updated to IE7. I plan on keeping my wife's computer running IE6 until Google Analytics shows me that the percentage of IE6 users has dropped to a level I can live with.
/DaveS
