I'm very new to dotnetnuke, and just starting to do the skinning tutorial that you provided. Which I must say, is very clear and helpful. I have a question though about the look of the skin. I'm sorry if this sounds very basic. I did the vortex music tutorial, and when I upload the skin on my portal, whole display became to big for the screen and i have to use the scroll bar to see the login button on the right. I followed your instructions and set the table width to 770, but it's still too big. I'm not sure what I did wrong. And also I started doing the pure css skin and when I used the House of Nuke menu I got this error on the page.DotNetNuke.Services.Exceptions.ModuleLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at TimRolands.DNN.SkinObjects.HouseMenuSkinObject.HouseMenuSkinObject.Page_Load(Object sender, EventArgs e) --- End of inner exception stack trace ---Please advise, and thank you so much!B
