I have completed a skin sing this techniques from Issue 25
and started on making sure that it is css and xhtml compliant. I am using DNN
4.5.3 rather than DNN 4.4.0 as you used.
I applied the changes to Default.aspx and other DNngiblets
outlined in your two issues covering that. As a check I went back to you
DNN_layouts 2pane_main skin and still have 36 errors. Most the errors have to
do with the Solpart menu bits being included and the poor html used to call
them {upper case no ending /’s etc} Red
highlights some the errors.
<SCRIPT SRC=
"/ASI3/controls/SolpartMenu/spmenu.js"></script>
"dnn_dnnMENU_ctldnnMENU_divOuterTables">
…pan id="dnn_dnnMENU_ctldnnMENU" name=
"dnn$dnnMENU$ctldnnMENU" BackColor="#333
IconBackgroundColor=
"#333333" HlColor="#FF8080" ShColor="#40
The aspx from your sink on DNN 4.5.3 DOES include a call to the
Solpart bits when DNN converts HTML to aspx.
<%</span><span style="color: blue;">@</span><span style=""> <span style="color: rgb(163, 21, 21);">Register</span> <span style="color: red;">TagPrefix</span><span style="color: blue;">="dnn"</span> <span style="color: red;">TagName</span><span style="color: blue;">="MENU"</span> <span style="color: red;">Src</span><span style="color: blue;">="~/Admin/Skins/SolPartMenu.ascx"</span> <span style="background: yellow none repeat scroll 0%; -moz-background-clip: -moz-initial; -moz-background-origin: -moz-initial; -moz-background-inline-policy: -moz-initial;">%>
However, deleting it doesn’t seem to help. Any idea on where to goto next in
figuring our how the solpart bits are getting included?
In my case I always only do the aspx and have no HTML files at all.
I also have located an error in the html generated by the Snapsis 3.0 silver
tab hover menu that I use where the W3C validator caught a couple extra
ending ’s generated by it when that page had children.
Also I have grave dificulties in getting the IE type sizes correct because
the changes in the iehacks.css file didn’t work at all. After some digging
I realized that Lee has his FCKeditor set up to use aroung t
ext or
’s for newlines. I have mine set up for
around
paragraphs. IE would only be happy with the font-soze CSS if I included
it in the p{font-size: x-small;} rather than then
body p{font-size: x-small;}.
That took a few hours before I thought of it and tried it!
Regards,
Dave Snow
