Hello - I am new to Webdesign but have had some success putting together a very simple skin (currently being worked on at
www.manufactsure.co.uk) with three Panes:
Content Pane at the top - generally left empty
Beneath this:
Left Pane: Main content (see below)
Right Pane: Image in a Text/HTML module
At the moment the Left hand pane has two text/html modules: the top one with the main text of each page and the one below with a page title as an image. I am manually aligning the modules to fit on the page.
I would prefer to redesign the skin to have the Right Pane alongside two panes on the left - the first aligned at the top of the page and the second aligned at the bottom - but I can't work out how to do it!
I appreciate that this is very simple but I don'treally know where to start and your help would be appreciated. . .
