Hi Lee,
I feel priviledged to have the master himself answer my question
Unfortunatly i do not have an external URL to point you at. Its running on a test server at the moment. However, i do have a link to static page design. If you take everything within the body tags, this is the code that is used for the DNN skin.
http://www.dcwebspace.pwp.blueyonder.co.uk/Home.htm
The css for the page can also be found here:
http://www.dcwebspace.pwp.blueyonder.co.uk/Skin.css
Its worth mentioning that the above page is valid (except the UTF Byte Mark warning). Like i said, it is only when DNN parses the skin that the problem occurs.
I checked the site and I have no modules on the page at this point. I wanted to get the skin valid before i started to validate the modules as well.
Thanks for your help.
Dave Clayton
