CSS skin attempt--
http://avw.isilm.comThe above link is to a site im working on for a client using no tables. I am just trying to get things positioned correctly (so none of the content image links go anywhere).
Originally, I had a div surrounding both the banner kitchen img pane and the welcome home pane. Photopane floated left, Welcome pane floated right. With a background color of white with a gray border surrounding them both.
The darned thing wouldnt grow with the two panes it was in. If I remember correctly, a similar topic was covered where when the footer pane was "clear:both" the blue bg came in fine, but I cant get it to work.
I like the way it looks now much better then i had before, but am curious as to why the heck it wouldnt show (the only way i could get it to show was by defining a height for the div).
I would greatly appreciate it if someone could help me understand why it wouldnt grow.
Thank you,
Charlie
