You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
How to remove Web search option form menu?
Last Post 10/01/2007 3:39 PM by
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
SHakani
09/30/2007 4:38 PM
Hi there,
Is there anyway I can remove the web search option from the menu? also,
is there anyway I can change the web search to some other search engine other then google?
I'm using Dotnetnuke 4.5.0
Thank you,
Saleem
DNN MVP
10/01/2007 9:35 AM
The Search tool is a Token that can be added/removed to your site's skin. So, if you want to alter it, you alter it in your skin.
This code appears in the DNNBlue skin (note that I've changed the brackets to square brackets so that they will render nicely here):
ascx file: [dnn:SEARCH runat="server" id="dnnSEARCH" showWeb="True" showSite="True" /]
If you change showWeb="True" to showWeb="False" you will get rid of the web search button.
The text that is a prototype for the search string is in a localized text file. Use the Language Editor and look for the localized text under LocalResources/Admin/Skins/App_LocalResources/Search.ascx. You'll also find a second URL configured for searching msn.
Joe Craig,
Patapsco Research Group
Complete DNN Support
SHakani
10/01/2007 11:59 AM
Hi Lee, I can't find that option anywhere.. Could you please confirm if i'm looking in the right place.
Admin-> Languages -> Admin -> Skins -> AppLocalResources -> Search.ascx
Thank you,
Saleem
10/01/2007 1:53 PM
If you wish to change the settings of the search token as Joe refers to then you need to edit your skin files. - you could double check the code with how we have implemented it in the
Andreas 01
skin
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
DNN MVP
10/01/2007 3:39 PM
Posted By Shakani on 01 Oct 2007 11:59 AM
Thank you,
Saleem
That's not quite the order I mentioned in my messages ...
After you get into the Language Editor, there is a tree control in the left column. You need to look there.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
