I'm currently looking at a re-design of the site, in particular a better navigation method for quick access to the website.
Does anyone have any suggestions on how they would find it easier to navigate around the site?
I need to re-organise the navigation because as more tutorials are added it is going to become very confusing to navigate around the menus.
My current idea is to have a main heading menu at the top, probably using the same categories as the current menu, but with no sub menus.
Then on the left hand side of the page it will display the sub-menu categories.
On the main tutorials page it will display a list of titles of every single tutorial we have created, grouped into category, ie: skinning, core modules etc.
Then if you click on a sub-menu item on the left hand side it will display the list of tutorials in that category but with the descriptions, as you can see on this page: (Skinning category)
http://www.dnncreative.com/Tutorial...fault.aspxI think this will be the easiest way to quickly view which tutorials are available, does anyone have any other suggestions?
