You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Skinning Toolkit
Skinning Toolkit
Multi language store module
Last Post 10/01/2007 9:10 AM by
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Kriz Van Looy
09/24/2007 3:43 AM
I am trying to adapt the dnn Store module to a multi - language store module.
I obtained the source code from the dnn website and opened this solution in VS2005.
When I try to build the solution I get a huge number of errors that prety much all look like this one:
The type or namespace name 'Common' does not exist in the namespace 'DotNetNuke' (are you missing an assembly reference?)
Does anyone know what's the cause of this problem? I am new to dnn...
Thanks in advance
DNN MVP
09/24/2007 5:38 AM
The store needs to be built with the DotNetNuke components. In other words, install either the install or source packages - you probably only need install - then install the store components, and then you should be able to build it.
But ... is there a particular reason why you want to be building it? Just install the Install version of DotNetNuke, get it running, and then install the Install version of the Store module. There's no building required! Not of DotNetNuke, and not of the Store.
If you are a beginner, I'd recommend that you click the Tutorials link at the top of this page, and start reviewing the Beginners tutorials.
On of the great features of DotNetNuke is that you don't need to build it. You just install and run!
Joe Craig,
Patapsco Research Group
Complete DNN Support
DNN MVP
09/24/2007 5:39 AM
As for building a multi-language version, use the multi-language capabilities of DotNetNuke and skip all of that.
Joe Craig,
Kriz Van Looy
09/24/2007 6:22 AM
Thanks for your reaction.
I've already installed the install version of the store module into my dotnetnuke website. This works great, but I would like to have a multi - language store.
How is it possible to adapt the store without adapting the source code and rebuilding it?
Thanks in advance
DNN MVP
09/24/2007 9:29 PM
After thinking about this, I realize that you'll need to translate all of the store contents, descriptions, etc. to all of the languages.
If you're really serious, I suppose you can install one version of the store for each language you plan to support. That seems like a lot of work!
Joe Craig,
Kriz Van Looy
09/25/2007 2:25 AM
Yes this is indeed what I meant. My website should be multi - language from start to end, so the store should also be multi - language.
Installing 3 versions of the store seems complex to me.. Can't I just adapt the source code to support multi - language?
When I try to open this source code project I get the following error:
"unable to get the project file from the web server"
The project opens in VS2003, I can see al the files and projects but the last one ("DotNetNuke") is unavailable...
I also got a huge number of errors stating that I am missing an assembly reference...
Any ideas?
thanks in advance
10/01/2007 9:10 AM
If you wish to set up a multi language store I would suggest having a look at Catalook, there are several language packs which you can purchase for the store.
http://www.dnnsoft.com/
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Skinning Toolkit
Skinning Toolkit
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
