Hi Lee
In your FCKEditor tutorial you inserted your own styles into the FCKStyles.xml fie based on the additional styles on the portal skin.css.
My question is, will the new styles on the FCKStyle sheet work on every page within that site?
I know that you said that due to a bug within the editor that extra styles from different skins cannot as be included.
However, if I use a page (within the same site) which differs from the main portal page and therefore uses its own skin.css will it be able to use the extra FCKStyles, taken from the portal skin.css. Or must I also insert the extra styles into the every skin.css which differs from the portal?
Regards
Lynn
