Those of you that are using the FCK Text Editor will be pleased to here that today Locopon has released a new version.
For those of you that don't know about FCK, it is an online Text Editor
that you can use instead of the standard Free Text Box editor that
comes with DotNetNuke.
The latest version includes the following:
2005/oct/25 (02.00.00) (Test version)
- Upgrade: Now FCKEditor 2.1.1 is used (Compiled under DNN 3.1.1)
Added: Support for customization per instance, per module and per portal.
Added: Simple support for localized templates for image, flash and link gallery
(Need improvement)
- Added: Support for the new flash gallery and the quick
upload
- Added: Now image, flash and link galleries include your page .css
files
- Added: Support for ...
and others
Added: Support to show your DNN .css classes in the styles dropdownlist
You can read further details about FCK Editor here:
http://dnn.tiendaboliviana.com/web/Default.aspx?tabid=76
