Hi Lee,
I am also trying a clean install. I can't reinstall Windows XP though and I highly doubt it's the cause of my problem.
I removed SQL Server 2005 and installed SQL Server 2005 Express instead (to synchronise with my online environment, which runs on express). I need to be able to port as fast and reliable as possible.
The symptom of my problem is different:
When I follow your video (xp pro & iis) and use dnn 4.5.5 instead of 4.5.1, i get forwarded to //Install/UnderConstruction. The message "This site is currently Unavailable" is shown.
Do you know what is going on? Other people have experienced this as well:
http://www.dotnetnuke.com/Community...fault.aspxThey suggest something to do with the database, having had no issues with 4.5.1. Could it be that web.config settings must be adjusted in 4.5.5, even when using sql server express?
Cheers, Willem
