David
Nuke Master Posts:152
08/06/2007 3:34 PM |
What no videos to go with the skins this month ;=}
I like the new DNN Creative Skin. It is nice to see that the ContentPane text is very close to the top of the HTML page and that the menu is after it.
I haven't installed the skins yet, but I do wish that there was another Menu choice for CSS skins than the House of Nuke. I have had problem with it, as I need a multi-level horizontal menu. Also there doesn't seem to have been any on-going development of it for a couple of years. Are there any other choices - free or for pay? BTW which version of the House of Nuke menu are you using?
I am currently using DNN360's menu. I have looked at the Snapsis menu, which I have seen do what I want. However, the docs don't tell how to get it to work the way I like.
You are cornering the market on CSS xhtml compliant DNN skins! Almost nobody else seems to be doing them. Maybe now that you have produced 5 of them others, including DNN, will be forced into doing some - I hope.
Keep up the good work,
/DaveS
08/06/2007 8:10 PM |
Take a look at Snapsis' CSS NavMenu. It is a pure CSS menu. It's also quite flexible. |
ismet dumlupinar
Nuke Active Member Posts:33
Lee Sykes DNN Creative Staff
Nuke Master VI Posts:4945
08/07/2007 4:28 AM |
Nice to hear you like the skin. - Yes the contentpane source code technique is a new one that I have developed which mixes the use of floats for the content and absolute positioning for other elements such as menu / login links etc. so that they can be placed after the main content.
House of Nuke version on the the new skins is 1.4beta - I think Tim is currently working on a new version.
Red Leaf was orginally designed for v1.3
Yes I am going to take a look at the snapsis menu as it looks as though it could be useful for those types of menus.
Cheers,
Nicola Stratfield
Nuke Newbie Posts:4
Nicola Stratfield
Nuke Newbie Posts:4
08/08/2007 4:48 AM |
There is also skin for sale Andrea - on snowcovered too, but anyway it all works out at the end of the day. Everyone will think theirs is best and they all look ok to me. my reason to post on here was to tell this person that if they have the snapsis menu they can use the code in the skincovered skin. It was not to compare which one is better. thanks /Nic |
David
08/09/2007 5:14 PM |
I just took a look at the guts of your new DNNCreative skin vs the 5 free ones. I hope that you will do a video on the SEO optimizations that appear in the DNN Creative skin and css file so that the ContentPane text appears ahead of the menu and many other items in the HTML file.
I am sure that they were a lot of work and that is why they don't appear in the free skins. I suspect that a lot of debugging went into the absolute positions that makes it work.
Now I have to figure out how to do the same things for my site. I hope that it isn't as much work as I suspect.
Like your new site layout using the background for the color and having very plain containers. |
08/13/2007 8:38 AM |
Hi Dave,
The 5 free skins layout structure is identical to the original designers templates that they came from which is why they don't use the new method I have developed in the dnn creative skin.
It wasn't actually that much work to use absolute positioning and I will be creating a video on this in a future issue. - If you are in a rush you may be able to work it out from looking at the CSS code of the DNN creative skin using the Firefox web developers toolbar.
Thomas Groman
Nuke Newbie Posts:4
08/13/2007 11:40 AM |
curiously_green.template is not a valid Portal Template File.
Any idea why I may be getting this error when using the Site Wizard to build the curiously_green template?
I've extracted: curiously_green.template and curiously_green.template.resources to \Portals\_default.
Any help would be appreciated... |
Michael Gerholdt
Nuke Newbie Posts:8
08/13/2007 12:47 PM |
I have been experimenting with CSS skin in DNN. Whenever I swap out the default.aspx file for the one that has an XHTML doctype, I only see a blank page - no content whatsover, just a white screen.
Is there a change needed in web.config to make this work? I've seen mention of that here and there but it isn't clear that such a change is needed.
Sorry if I missed this somewhere in the docs or tutorials. |
Michael Gerholdt
Nuke Newbie Posts:8
08/13/2007 12:49 PM |
Also ... has anyone converted the Active Forums template to CSS non-table-based layout? |
08/17/2007 5:42 AM |
Posted By pmichael on 13 Aug 2007 12:47 PM
If you are using the latest version of DNN you do not need to change the default.aspx file for XHTML transitional DOC TYPES, they are automatically configured by the skin. Have a look at:
