Hi Andrew,
I haven't looked that deeply into shopping carts, all I can suggest is that you look around on Snowcovered. Catalook is one of the noticeable names, but I've noticed a lot of people struggle to set it up and I don't think it's very user friendly.
Adjusting registration module, you have 2 options, programme your own or try out:
http://dnn310.ucanuse.com/PortalMod...fault.aspxI've heard mixed views on the module, so I would encourage you to test it thoroughly first before using it in a production environment.
I haven't used this module yet so i can't provide any advice, but it looks perfect for the job.
An enquiry form, there are a few modules on snowcovered, but again at the moment I can't recommend any, you may find the XMod module is useful, I used it for DNNv2, but haven't used it since - it does take a bit of reading though to set it up.
Lee
