Thanks Joe, the site which I will be moving will be a total site, ready to go. What you have described is pretty much what I have done. Yes, there is a bug but I posted in this forum and had it fixed in no time.
I had the hosting comany load up a fresh version of DNN for me, exported a site template and created the new site at the new location using the wizard. The first effort revealed that none of the additional module or skins which I had loaded were available at the new location, so I had to manually load all those and then create the site again.
I thought I had lost some content but it turned out that some of the settings in the modules had changed and I had to track those down and fix them. None of the images had come over so I had to upload all of those too.
It is certailnly doable using the export template but it's a bit clunky - I was hoping for a backup from one location restore to another solution but I suppose all referencing will be wrong.
I could create the website from scratch at the new location but, where I am revamping an existing site, I need to make an entry in the hosts file on my local PC so that I don't go to the existing hosting server. That works fine for me but it means playing around on the clent's site when I need to show them something (not a good image
That's the reason I created the staging area - it's a tidy solution and, once I get it secure, will work well. I'm then left with moving the whole, completed site (modules, skins, settings, content, images) to it's final destination.
I guess I'll have to develop a routine for all the steps necessary to export and use the portal template.
Thanks again for your help. Steve
