Is it not necessary to modify the Machine Key Validation codes that come with the standard DNN install to those of your host server?
Ron
Dear Lee:
Thanks for the reply. That cleared up that question.
In the meantime however, I decided to do a fresh install. It got down to Configuring the host account and then bombed out. Do you think that is also a permission problem?
