Hi all,I made a rough implementation of the cool TransMenu 2.0 for DNN (4.5.3) and would like to share this with you. No guarantee for working, but have a try, it's free.You can see my implementation here, just hover over the different menu items: http://www.gbsdeplantage.nl, it's very cool!You can download it here: http://www.bsoft.nl/TransMenu.zip. Read the installation.txt its quite simple to use.Regards,Berthold
It's great to hear it works on your site. I do not have issues with that slash.Hmmm you mention the spacing between the main items and the dropdowns... I didn't noticed it before. It's something of transmenu I guess. Have a look in the tansmenu.js file, in the top of that file there are some settings you may change, maybe this helps.Regards,Berthold
I did a small bug fix. When using Internet Explorer there was a limitation of sub menu's (8), that has been fixed now.Enjoy!http://www.bsoft.nl/TransMenu.zip
Great menu control ... the download and install didn't hurt a bit.
