Hiwas looking at tutorial from issue 22 on transferring live to local for testing updatesi use websecurestores hosting (SQL 2005) i have downloaded database on trying to restore database i get error belowSystem.Data.SqlClient.SqlError: The operating system returned the error '5(error not found)' while attempting 'RestoreContainer::ValidateTargetForCreation' on 'c:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\A3310284.mdf'. (Microsoft.SqlServer.Express.Smo)
For help, click: http://go.microsoft.com/fwlink?Prod...nkId=20476the OS i am using is Vista Home Premium, i have had no problems using SQL Express 2005 for local builds to test DNN and Moduleshas anyone else had this problem, and how did they able to fixThanks
Ignore request got it fixed.the problem was hosting has database on different location, on restore database page, click optionsI had to change restore locationfromE:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\toC:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\hope this helps out anybody Martin
