You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
DNN Creative Articles
Live website to local host using XP Home
Last Post 08/10/2007 9:37 AM by
Gym Media
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Andrew Davis
07/04/2007 11:52 AM
I have just listened to Issue 22 Transferring a live website to local host. It seems to depend on having IIS installed - which correct me if I am wrong, does not run on Windows XP Home Edition. Does this procedure work without IIS? or do I need to change my operating system?
Stefan
07/04/2007 12:18 PM
You don't need IIS. In my previous post, I asked Lee if there are any issues in this configuration.
You can use the free ASP.Net Development Web Server built into VWD and VS 2005. You need to make sure that your ports match. When Lee talks about setting the HTTP Alias before the backup, this needs to be set to the ASP.Net Development Web Server port you want to use. For example:
localhost:1269/wwwroot
Stefan
07/04/2007 2:05 PM
Hello Yorkshirebob,
I see stefan helped you out, but I can't resist writing this after seeing your username:
'Ey up, ows it going?!'
Cheers from YorkshireLee
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Andrew Davis
07/06/2007 10:52 AM
Thanks I'll give it go!
Andrew Davis
08/10/2007 2:28 AM
it's taken a while to get back to this, but I have now got as far as trying to start the install and get the following error, can you give me any suggestions as to what it means?
DotNetNuke Upgrade Error
The Assembly Version ( [ASSEMBLYVERSION] ) does not match the Database Version ( [DATABASEVERSION] )
ERROR: Could not connect to database.
A connection was successfully established with the server, but then an error occurred during the login process. (provider: Shared Memory Provider, error: 0 - No process is on the other end of the pipe.)
DNN MVP
08/10/2007 6:26 AM
Is this a new install?
If you are using one of the latest versions, there should be an installation "wizard". The wizard includes a section on setting up access to the database. Are you running from there?
Joe Craig,
Patapsco Research Group
Complete DNN Support
Gym Media
08/10/2007 9:37 AM
yorkshirebob,
Have you checked your connection string? Look in your web.config under appSettings for an entry for SiteSQLServer. Check your settings, and make sure your username & password is correct.
GymnasticsMeida.com
The Ultimate Portal for the Ultimate Sport
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
