<!-- Start_Module_4826 -->
Considero
Alive Media Player is 5-in-1 multimedia player
module for DotNetNuke portal platform.
What can it play?
- FLV Flash video files
- MP3 music files
- JPG, GIF, PNG and other image files
- SWF Flash files
- iTunes, RSS 2.0, ATOM, XSPF podcast playlists
- Custom XML playlists
What are supported media sources?
- It can play files from your DNN server (set
folder, single file or
playlist to play)
- Play podcasts, files or custom playlists from other
web servers worldwide
What are the module features?
- One click to turn your DNN into multimedia
audio/video portal. This is standard DotNetNuke module, easy to
install, easy to use. All you need is to add module to your portal and
set the player mode and media source through
the module settings.
- It uses JavaScript to avoid "Click to activate this user control" message in
Internet Explorer
- Module is localizable through standard DNN localization
- Automatic playlist generation. Just select the
folder with media files and it will generate playlist
on-the-fly!
- Set the preview image or album cover for MP3 or FLV file
- You can customize width, hight and colors of the player
- Set the dimensions, position and behaviour of the
playlist
- Player supports watermark logo image
- If you play MP3 music files, you can enable the
graphical equalizer
- Fullscreen mode for images and FLV Flash video
- Enable/disable file download
- Set buffer lenght in seconds. Useful for large files and
podcast streaming.
- And the classic player features like volume, autostart, repeat,
shuffle...
