Hi there, I want to let you know this tutorial is GREAT!!!!!! The first tutorial I found which described so detailed the installation. Realy good. I had some experience with the v355. With that knowledge this was a peace of cake. Now I have to install this on a hosted webserver. I wonder if that goes as smooth as the local iinstallation. But with your tutorial I'am confident it will. Thanks again Regards Roel Hof Netherlands
