How do I "turn off" or "remove" the little printer icon that displays on all the modules I add to DNN?
I'm guessing it is an actionbutton in the container....
If it is, where can I find what these actionbuttons do and their numbering?
I have read the "skinning" pdf from DNN 4 documention.
Thanks.
Andrew
Hi Joe
Thanks for your response, I can see how XML is quite similar to HTML.
Had trouble locating the module settings file for the module. I have already tried to set as false in the "default.template" but that didn't work.
Ended up just installing a transparent container instead and that is working ok.
thanks
Kim
