I have been using the FCKedit with it pointed to my skin.css file so that all of my classes are available. This has work great until I started to get a bit fancier. Normally the FCKeditor applies the class to a
that encompases the elements that you have selected. However, I now have some classes that should be applied to
rather than spans. How do I indicate to the FCKeditor that I want it to do that? In the old statix way I could create an xml file to do it, but I really don't want to have to maintain the extra files. When I edit the skin.css I like the fact that it shows up in the FCKeditor.
I just went pact to your Isses 8 and was adding imageleftsidecaption class to my skin.css when this problem show up. Those classes really do need to be in a
and not a span. In the style dropdoen the FCKeditor actually add (span) to them.
Are there any easy solutions? I suspect that some of the classes should actually be applied to the
not that this is the break being used.
Lee are you thinking of updating your FCKedit articles now that its part of DNN?
/Dave
