You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Collapsible Side menu
Last Post 05/21/2007 2:45 AM by
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
jamx551
05/10/2007 12:21 PM
Hi lee
How do you make a collapsible Side menu using SOLPARTMENU
if not solpartmenu whats your other suggestion to create such menu
So instead of the usual pop submenu the menu items expands to show submenu below it and collapses when you click again
thanks
05/11/2007 3:30 AM
I do not think this is possible with SolpartMenu, I would suggest you check out the tree view menu. There is an example of this in the DNN blue vertical skin.
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
jamx551
05/11/2007 4:15 AM
Hi lee
i see. can you send me the link to the blue vertical skin?
thanks
05/11/2007 4:26 AM
It comes installed with your DotNetNuke installation - you should be able to go into the _default/skins folder and see the skin in there.
- You can test it out by just selecting the skin for a page - it should already be installed,
DotNetNuke Podcasts
Twitter:
jamx551
05/17/2007 4:20 PM
Lee
I tried applying DNN-Blue-Vertical Menu-Fixed width (assuming this is the collapsible menu you were talking about)
but when I click Update I got the ff error:
An error has occurred.
DotNetNuke.Services.Exceptions.PageLoadException: Value cannot be null. Parameter name: type ---> System.ArgumentNullException: Value cannot be null. Parameter name: type at System.Activator.CreateInstance(Type type, Boolean nonPublic) at DotNetNuke.Framework.Reflection.CreateObject(String TypeName, String CacheKey, Boolean UseCache) at DotNetNuke.Framework.Reflection.CreateObject(String ObjectProviderType, String ObjectProviderName, String ObjectNamespace, String ObjectAssemblyName, Boolean UseCache) at DotNetNuke.Modules.NavigationProvider.NavigationProvider.Instance(String FriendlyName) at DotNetNuke.UI.Skins.NavObjectBase.InitializeNavControl(Control objParent, String strDefaultProvider) at DotNetNuke.UI.Skins.Controls.TreeViewMenu.OnInit(EventArgs e) in D:\www\ariel.premierpos.com\Admin\Skins\TreeViewMenu.ascx.vb:line 507 at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Control.AddedControl(Control control, Int32 index) at System.Web.UI.ControlCollection.Add(Control child) at DotNetNuke.Framework.DefaultPage.Page_Init(Object sender, EventArgs e) in D:\www\ariel.premierpos.com\Default.aspx.vb:line 499 at System.Web.UI.Control.OnInit(EventArgs e) at System.Web.UI.Page.OnInit(EventArgs e) at DotNetNuke.Framework.PageBase.OnInit(EventArgs e) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) --- End of inner exception stack trace ---
What could be wrong?
Also what's really the syntax for TREEVIEWMENU ? because when I used it in my skin all what appears in the browser is still [TREEVIEWMENU]
thanks
05/21/2007 2:45 AM
Which version of DNN are you using?
If it is 4.4.1 some dll files were missing from the install version which maybe causing this error.
the same problem occurred here:
How to fix the [DROPDOWNACTIONS] token bug in DotNetNuke 4.4.1
If you download version 4.5.1 go to the bin folder and copy this dll file into the bin folder of your 4.4.1 installation it should solve your problem:
DotNetNuke.DNNTreeNavigationProvider.dll
DotNetNuke Podcasts
Twitter:
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
