Thanks for that Info and warning.
I will see if I can find someone using the DNN Store Modules. It’s not a Module you want a stack of Bugs in.
What system are you using Lee?
About the Google Search Box.
After I got the HouseMenu working and the page looked OK, I added a Text Module in the content pane and set it to display on all pages.
After I put in the Google Code it pushed down both Left and Right Pane content below the Content pane. On one page it moved an existing content Module to the bottom pane.
Finally I wasn’t able to delete this Modules, I had to go in and remove the Google Code before I could delete the Module's!!
Anyone had similar problems?
Anyone using the Google Search box?
Cheers
Olle..
www.goldcoastwebwiz.com
