Thanks for your mail response Lee.
It’s slow sometimes – but eventually I get it right – I think?
The Red Leaf skin is CSS based, while the Vortex one is Table based?
Consequently I need to put in table rows for Google code and the classes I need to add. As opposed to the DIV tags you are using in the CSS skin?
(Google now say it can take several day to have the AdSense account, so maybe I should do the CSS-Skinning-Tutorial while I wait.)
Cheers
Olle….
Hi Olle,
They are just names for the skins, you can give your skin any name you wish,
Hi Lee
I’m waiting………….._
In the meantime I checked the tutorial, and you have “Index.html” and “Transparent.htm” files in the red Leaf skin.
What does those files corresponds to in the Vortex Skin we created?
Do I need to create these files?
Cheers
Olle….
