Hi lee,
This is a new 4.5.5 installation. I setup all the folders with minimal RW some with RWW. The folder that is acting like the root, has the root permisions checked.
I can not check on the individual file permissions, godaddy dosent allow that , and when I asked them to check on it, they said they could not provide application specific information.
I wondered that if Default.aspx wasnt enabled as a default file in the IIS could that casue the problem, I have asked that question as well. I just wish there was some way to see what the acutal error is
