When a script installation, installed my DNN it put the primary path to portal 0 at chickensplus.info/DNn. I need to change that to chickensplus.info. I know I will have to go "behind the scenes" to do this but can anyone tell me all the places I would have to edit. I am also assuming their are some tables I would have to change manually. I have my install working , but right now if you try to restart the program from the host menu, you get a permissions error. I think its becusase its looking for webconfig in the DNN folder, and its not there anymore, Its on the root (Thank you
