I judt dowenloaded the install for DNN 4.3.2 and found both release.config and web.config in the unzipped files. Should I delete web.config and then rename release.config and then install? I found Mr. Walker's installation instructions on another website and he says to rename release.config to web.config after installation. But once again, Solution Explorer in VS 2005 lists both release.config and web.config.
Thanks for your help.
Buddy
Lee:
Thanks for the clarification.
