Hi Lee
I read with interest your article regarding Http compression for DNN.
You mentioned to add a line to code within the modules. Can you be more specific, i.e which file within the desktopmodule/ module/folder should this code be placed and I presume the code should be inserted at the top of the page.
Example of which modules may not be suitable for compression.
Lynn
