Hi Eureka,Thanks a lot for ur such a spontaneous response as i need this information on priority basis. so can you pls. advice me is there any other software available for it . I will try to follow the dreamweaver ( which u have just suggested to me ) but if you can please advice any other s/w for it i eill be obliged.Thanks & RegardsPragya
Hi Eureka!!
So what i concluded from your last two mails is that if i want i can use dreamweaver or visual web developer to create skin than later on i can apply it to my website. So i can use CSS and Skin Toolkit as well for it. I was just trying to figure out other options as well for crating options as well , so as DNN provides us Flexibility of creating website is it possible that we can get the same flexibilty for skin solution as well i mean is it possible to have tool through which we can generate skin of our choice like we can customize the skin acc. to our wish. If one like to change the color or containers or say background color than one can do so by selecting those features and than generate a skin acc. i mean is it possible to avoid writing up the large code for generating the skin.i hope that you are going to advice me on this issue as i need your valuable guidance.Meanwhile i am going through skninning tutorials as well available on your site.Hoping for a positive and quick response from your end. Thanks & RegardsPragya
