Hi LeeIn your article "Semantic code and header tags within DotNetNuke skins" http://www.dnncreative.com/tabid/26...fault.aspxYou suggest inserting h1 and h2 header tags into the container skins. The css styling for the header tags located in the skin.css file.That is fine if you require the text colour for all the container headers to be the same i.e. color: black; However, if the container background colours differ, then black text may not be suitable. Would you suggest having a selection of h2 headers specifying various colours located in the skin.css file and in the container the relevant colour: h2 class="white" for example. Or would it be more efficient to specify the custom coloured css styling for the required h2 class colour within each individual coloured container.css file?ThanksLynn
