Is there any tutorials on how to create new modules ??
Assuming you are using DNN4 and VWD and SQL Express, try the following link:
http://www.adefwebserver.com/DotNet...efault.htm
Also make sure you read:
http://forums.asp.net/1114393/ShowPost.aspx
Creating a module in DNN4 is much easier than with DNN3 but it still seems complex at first!
John Stodden
Hi I am new to dotnet nuke and unable to proceed with the pdf and the videosCan anyone please tell me how to cretae a new template other than default.aspx and how to edit the default.aspx
